Enables or disables an MEP.
domain_name |
Specifies the domain name. |
association_name |
IEEE 802.1ag or ITU-T Y.1731 association name. |
port_list |
Specifies the ports to configure. |
up |
Specifies that the end point is up. |
down |
Specifies that the end point is down. |
MEP is enabled by default.
Use this command to enable or disable an MEP.
Use the show cfm command to verify your configuration.
This command was first available in ExtremeXOS 12.3.
